Keiser's 7.3 + turbo noob build
WrenchWhore
Lake Havasu City
@Old Goat It was an awesome event with TONS of older trucks. Mostly 60s, 70s, 80s trucks . People from all over the US came from Alaska, Canada, Washington etc. The weather was absolutely beautiful and you could pull you truck right next to the water and even on the beach if you wanted. There were even a handful of IDI's in bullnose trucks. Also a bunch of Cummins swaps and Powerstroke swaps. Full frame off swaps too. Makes me wish I broughy MY Brick IDI since I would have won by default. Somehow nobody had a bricknose truck there. I hear ya though. I stay out of CA at all costs unless it's for work or family. I get one taste of that SoCal traffic and I want to race back home.
WrenchWhore
Lake Havasu City
We're getting closer fellas! Rebuilt the turbo with fresh bushings and seals. Took me a hot minute to get the turbo in it's final resting home. Getting the passenger side exhaust manifold, turbo up pipe/slip joint, and turbo pedestal all lined up so they didn't bind was a chore but I eventually got it. Just had to loosen the bolts on the turbo and clock the hot side and cold side. Test fit the crossover pipe and all seems good to go. Wrapped up the turbo with all the factory heat shields.
Buttoned up the thermostat housing with a Motorcraft t-stat and gasket
installed lower radiator elbow with Motorcraft gasket.
Injectors are a mixture of new and old as well as the glow plugs being a mixture of part numbers. When I pull the 6.9 motor from my truck i'll transfer the brand new R&D IDI injectors and Motorcraft glowplugs onto the donor engine.
I noticed when I pulled the injectors on the 7.3 donor engine that it had some rancid fuel in two of the injector chambers. I'm thinking this would explain my rough choppy idle when I bench ran the engine before repairs. Compression numbers seemed great but all the supporting parts were just...junk really.
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
We're getting closer fellas! Rebuilt the turbo with fresh bushings and seals. Took me a hot minute to get the turbo in it's final resting home. Getting the PS exhaust manifold, turbo up pipe/slip joint, and turbo pedestal all lines up so they didn't bind was a chore but I eventually got it. Just had to loosen the bolts on the turbo and clock the hot side and cold side. Test fit the crossover pipe and all seems good to go. Wrapped up the turbo with all the factory heat shields.
Nice looking engine in the pics
The_Josh_Bear
Western WA
Now do it with the engine in the truck, for the first time ever! LOL
Great progress, engine looks so clean like that.
Keep up the good work!
WrenchWhore
Lake Havasu City
I absolutely see why people break the turbo pedestal on these factory turbos. They've got to be JUST right for them to all be happy together. Thank you for the kind words. Normally I rush everything and the end results isn't something i'm proud of. While it's not 100% new engine and parts i'm REALLY trying to put this used engine together with forethought.
The_Josh_Bear
Western WA
I'd actually forgotten how frustrated I was putting my turbo on for the first time till I read that, and now just remembered how mad I was when I finally had it all together except the intake hat, not knowing you couldn't just slip it in there after the turbo was in place! I was in a special place for that one... -cuss
One of my favorite parts of having charge air cooling is that you don't have to care about that. I know it's not very often we have to move the intake hat or turbo-- but I still smile knowing that the two don't have to be installed together. :Thumbs Up
REM70
Staff online
