dyoung14
Is getting worn out
I keep blowing the fuse that goes to the brake lights and the warning lights, the warning lights i could care less about, but i got to have brake lights
Any suggestions?
Any suggestions?
What do the turn-signals do ??
Will they operate without blowing a fuse ??![]()
The turn signals still function![]()
I've been battling this nightmare with the clearance lights on the Moosestang. It blows the lighting fuse whenever I hit a good bump. So in the course of trying to figure out why, I was under the back end one day and wiggled a bunch of wires, and then next thing I knew, I had lost my right turn signal. Then I discovered that when I had the cruise control on, when I signaled to make a lane change to the left, the cruise would drop out. :***: This was really getting anoying. So I changed out the light bulbs... no difference. So I figured my turn signal issue must be related to the probing I was doing under the back, so I got back down under there and started unwrapping things. What I found was suitcase connector poisoning. At some point in this trucks life, somebody had used suitcase connectors to hook up trailer wires. Then later in it's life, these were removed, leaving the vampire bites to corrode. The right turn signal wire had broken internally. I spent about 3 hours trying to solder oxidized copper, splicing in replacement wire where needed and using heat shrink tubing on everything. What a pain! When it was over and done with, my turn signal was back, and the cruise control was OK again. But I still have that damn lighting fuse blowing on hard bumps. My next move is to install a lighting relay, and maybe a circuit breaker in place of a fuse.![]()
Your passenger headlight is really dim man remember we noticed that one day
Did you ever find the issue? My truck is doing that as wellI do remeber that, but i already fixed that problem, it had a loose wire on the headlight, i hope i can actually find the time to work on the truck today, but right now its raining![]()
