Johnson Hylift Lifters
gerlbaum
AZ
Has anyone ever used this brand before? They make them for our engine, made in the USA. They have four types, standard, race (these are variable bleed down, designed to bleed down at lower rpms if running a big cam), slow (slow bleed down, said to act like a flat design), and "e" type that helps prevent debris from blocking. Can also order special metal, and a host of other options. Their standard set is $420 which seems to process out to a normal set for our trucks.
Part number is A-2104.
http://www.hylift-johnson.com/products/product-catalog/
Hydro-idi
Lodi, California
Yes I used them in my rebuild. You can also call & make sure your getting the right ones. If I recall, they were way cheaper than anyone else for a set. Quality is damn good as well.
Hydro-idi
Lodi, California
I called Johnson hylift and told them my year/model of rig and they looked up the correct lifters for my application.
tel: (800) 441-1400
gerlbaum
AZ
Thanks. Probably should have figured I could order direct from them.
