Has anyone removed andinstalled the valley pan gasket. If the plug that fits in the rear hole isn'tinstalled there is noway the pan can seal tothe rear of the block. Its tuff to located said drain plug. Its got a 3/8 inch hex in it so it can be tightened down on the pan and hold it tight to the rear of the block. Use a flashlite and mirror. Maybe you can located it. Its back of the old cdr drain location that now is the turbo oil return to the pan. Where you felt the oil leak was coming from...
