raydav
I have a TACH N TIME. The bracket on the front engine cover has a tube at the zero mark, and a smaller tube 20 degrees later. I plugged the magnetic probe in the smaller tube because that is the one it fit.
I did a quick check at idle. I scrolled the timing light until the dampener groove was at zero. The screen said plus eight degrees.
I switched to the mag pickup. After adding twenty degrees for the offset of the second tube, the screen said zero degrees.
So what is it, plus eight or zero? I read another post where the two methods yielded results.
Suggestions?
Suggestions?
