You could do that. I don't have any diagrams for the tank selector. If so, I could figure it out for you.
So like an auxiliary tank that you'd use to refill the rear tank?not trying to down your method but I recently had my fsv quit working and havent had a chance to look at it since but the idea that immediately came to mind if my fsv indeed needed replaced was to pull it and rig it to where it will only suck from the rear tank. Then plumb a line from front tank to rear at the bottom of the tank and put a check valve or an asco valve(open/close flow solenoid) keyed by the ignition in the line to were the front tank would fill the back one as it drains. The check valve is neccesary because just running a line between the two would make filling up a pain.
This just seems like the obvious answer to me.
