Interesting IDI glow plug harness listed on eBay
tbrumm
Richland Center, WI
Quick search turns those up as a GP connector for a 6.0. Looks like he took a 6.0 harness and cut the plugs off and swapped on ring terminals.
tbrumm
Richland Center, WI
Thanks for your research, Laserjock! Those terminals certainly look like they would do the job. As large as those terminal are, they might be a little tight around the injectors and lines. I'll have to do a little more research.
outtowinpahc
Philadelphia
you you can use the correct nut and all ring terminals with a vac cap over the protruding stud.... cost is about 8 bucks this way
tbrumm
Richland Center, WI
Those things (the OP) look like push to connect plumbing fittings. They even sell a tool to pull them off that looks like something you would use to separate them.
Seven4eight
