intercooler, will it fit?
SPR1NK
Stevensville, MT
I have an intercooler that I believe is from a 6.4 powerstroke that I can get for free, but I don't know if it will fit and work properly, has anybody done this, or know if it's possible to make it fit and work properly?
SPR1NK
Stevensville, MT
I actually have a homebuilt bumper that sits a good bit further out than the stock one did, so I think it should clear there, but I wasn't sure if it was doable just because the intercooler seems to be a bit thinner than the radiator so the inlet and outlet would be right against the radiator instead of next to it, and the inlet(or outlet, not sure which) on one sure isn't straight, is at a funny angle
FORDF250HDXLT
Maine & Oklahoma
take it.put it on ebay and sell it.take the $ and by a tried and tested cxracing from ebay.
BDCarrillo
Abilene TX
6.4 intercoolers are going to be full of grime and oil due to the crankcase vent design of the engine. They also had serious problems with plastic end tank separation, since they were built in a similar fashion to radiators. Speaking from experience and research as a prior 6.4 owner.
The inlet/outlet config is horrible as well... one at the driver bottom and a goofy 45 at the passenger top. The mounting is less than ideal to retrofit... two pegs into grommets on the bottom and a couple bolts halfway up each side.
SPR1NK
Stevensville, MT
Sell it? Are these intercoolers that bad?
This one seems to be pretty clean from what I can tell, but obviously I can't check inside very wel, are these just that bad that it's not even with the effort to try to use?
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Radiators and Intercoolers are known issues on the 6.4's....... one of the most common issues.
If you really want to use a PSD CAC I would use a 6.0 or 7.3PSD one, or use the one suggested above.
