jaluhn83
Been thinking about how to setup an intercooler on my rig and here's what I've come up with:
I'm going to be running a HX35, typ4 cam, ~20.5 cr, head studs and am figuring on about 20-25 psi max boost. My intent is to maximize low end pulling power.
I've pretty much decided on running an air to water setup, probably from frozen boost. I have not been able to come up a good way to install an air to air unit without significant cosmetic changes (ie cutting the grill down to nothing) and the air to water system seem easier to setup.
I compute a max flow of ~750 cfm at max boost and 3000 rpm.
Looking at frozenboost, I couldn't find a good single unit that would fit well and flow enough. So what I'm now thinking it to run 2 in parallel, most likely a type 19. http://www.frozenboost.com/product_info.php?cPath=218&products_id=219&osCsid=a41403893444652f783ebfbca95eeb74 It looks like I can fit one on each side of the radiator vertically wedged in between the radiator / support, battery tray and engine. Driver's side would be tight with the ps pump and steering box, but I think it'll fit. This unit is rated at 550 cfm. The other option is a type 20 which is slightly smaller, but only rater at 350 cfm and thus marginal for max flow. Granted, it'd probably be fine, but the size difference is pretty minimal for the increase in flow rate and the cost is the same.
I'm thinking of running the compressor discharge over the pass valve cover and then down and forward under the vacuum pump and into the intercoolers from the bottom. I would then run piping from the intercooler tops around each side and into the intake manifold.
Part of the plan is to radically modify the intake essentially removing the entire center section. I'm planning to cut along the inside edge of the 'log' section of the manifold on both sides and weld a plate over that area on both sides making 2 separate runners similar to the PSD setup. Then I'll install a flange on the top of each between the center 2 cylinders and pipe each intercooler into one side.
Questions I still have:
What size of piping would you recommend for the intake side? Turbo outlet looks like 2 1/4", and intercooler inlet/outlets are 2 1/2 or 3" depending on which one I use. I'm thinking 2 1/2" would be sufficient but curious what ya'll think?
Any thoughts on fairing the pipe where it enters the intake itself? Ideally this corner would be a smooth radius but I don't really have room. Not sure how much a flow loss I'll wind up just welding an elbow straight onto the flange and having a sharp corner there.
Do you think there will be any balance issues? I'm thinking of running a section of pipe to connect the 2 sides of the intake but sure what size or where exactly.
Haven't figured out how to do the water side yet. I'm thinking I'll try to get a large custom radiator (largest stock is 12x24x1", thinking something closer to the AC condenser in size and 1" thick) and run water flow through the coolers in parallel. Biggest problem I can see is making sure to get sufficent flow for both coolers and getting it balanced. Or maybe just run 2 pumps.
Thoughts?
Thoughts?
