Intercooler piping
Posting some pics here for BobGreenslade. And other interested parties;Sweet;Sweet
first one is the hot side, the other one goes around behind the air filter box, but i have a hydroboost so their is lots of room.
k_williams1982
'01 Excursion 4x4
Santa Rosa, CA
I need to get ahold of you to figure out a price for an intake hat and some piping. I'm hoping to make some money before I take the job in Portland and get this IC installed.
sootman73
Wauseon, OH
i also need to figure the same if you are willing. i think i found an IC that a guy has sitting in his attic but not sure if hes gonna sell it to me. i desperately need an IC or at least water injection if i can't get that done.how much room is left behind the grill after the IC install? if i have two tranny coolers will is still fit? (they will be 1 inch thick at the most.)
Slade
Roseville CA
Here are some pictures of the intake hat that typ4 is building.
So the stud was long enough. By the way that is grade 8 allthread so no breakage worries.
Slade
Roseville CA
The allthread is fine I need to run it down and lock it down with the lock nut you provided. and eliminate the jam nut I used on the top. Once I get my connectors I should be up and running in a couple of days.
We're thinking of dragging the Jeeps down to Hollister next month so I'll have a chance to load the camper with the Jeep and trailer and check the temps.
Slade
Roseville CA
The intercooler is from a '01 7.3 and I used as much of the original pipes as I could.
dizdak
Winter Haven, FL
i am still turbo diesel dumb, the pics that Slade posted, is that a waste gated turbo or non waste gated? my factory turbo looks the same, but i don't know if it wasted gated or not..or if one is better than the other..
chevytaHOE5674
Ontonagon, Mi
That's wastegated.
one pipe is ps, other was from a dodge I think and a 3 inch ebay tubing kit, my ic is an 00 ps with 6inches cut off the top. and the hat is a couple different pieces. After I get rid of the 6 I have I will tell. lol
dizdak
Winter Haven, FL
thanks chevy! trying to learn my motor so i can start mods like this after i do the initial injectors and ip upgrade..
