The new VP arrived its not much difference between it and the old one that is guaranty.
I shined my light inside the new one. I finally can see how this Sucker put together. But still will cause the same issue regardless.
OLDBULL8 :
you stated I can't make a bigger hole like 1" in the new VP from the top opening thru the grommet which doesn't make any sense at least to me specially since every one here told me to put as much holes as I could at the time .
Please keep in mind that the only access I had was thru the grommet, any how the holes in the button of the new VP not much bigger if any, it's pretty much the same as the OLd stock one .
I guess I miss understood something along the way.
My thoughts would be a 1" hole between them 2 small holes from the bottom (By the arrow) that WILL Not penetrate all the way to the Middel tray. I am guessing that should be more than sufecient for the oil to return without backing up TOP
Is that sound about the right route to take as I want to fix this for good
