Is it possible to bolt it on backwards? This would make intercooling easier.. Only thing I can think of to interfere is IP and lines, but.. Would they?
Yep, I actually did that by accident on one of my put togethers. I didn't go as far as trying to install the IP and lines. Luckily I didn't even torque it down so I was able to continue with the new intake gasket that I had on hand.
Sorry, I wasn't in the research and development mode. The ATS turbo would never fit that way. R&D IDI performance sells a modded intake that makes intercooling easier, I would check that out if it interests you.
