Installing E pump.
Ididriver
Panama city beach
Truck is running on electric fuel.
I have a few kinks to work out but it dose start.
Apparently the block off plate isn't doing it's job that great it's leaking oil.
And one of my fittings is leaking a little fuel.
You can defiantly see the air bubbles in the clear screen on the fuel pump.
Bt the one thing that concerned me was the fuel level in the pump would drop to about half way after a few minutes of idleing?
Matrix37495
The Amish Wolfman
Terre Haute, IN
They don't like very thick fuels. I run WMO through mine but it's pretty thin when i'm done mixing it.
I'm glad its working well for you.
The way you wired the relay seems odd to me, but if it works for you, great. :)
Here's how i wire all my relays:
30- Battery power
87- Load
86- Signal
85- Ground
That's how gandalf posted it the first time. You want the high load part across 30/87 and the signal across 85/86. If you connected 30 to battery power and 87 to ground you would have a direct short to ground.
