Installing an RDT
MidnightBlade
Shiftin' Smooth
Johnstown, PA
How do you install a RDT? Do you remove the CDR and run the hose out there or what? I would like to put one on because I just don't trust the CDR.
MidnightBlade
Shiftin' Smooth
Johnstown, PA
I did a search and only came up with pics and complaints about smell. I need it to know if the CDR goes away completely or is just bypassed.
itsacrazyasian
residentcrazyasian
boca raton, fl
It goes away or blocked off depending on where it is.
My RDT comes off a banks style cdr adapter. basically it comes off the front of the timing housing and to a hose that cruves up a bit then heads towards the back of the truck. THe idea is to let the crankcase breathe and put a fish mouth on it at the end so you get a vacuum effect at speed to pull the vapors from the crankcase.
olsen726
