injector
plywood
Recovered N/A
Portland Oregon
Yep that's funny I recognize that seller. I got my Delphi's in my truck from him for around $180 I'd say maybe 10-12 years ago. On edit maybe 6 years ago can't remember but it's been some years anyway.
blakken
sweden
i recently hade a problem with low fuel pressure! now i have a duralift so its god.
but the sound started when i was driving it with low fuel pressure. its showed up to be a sqezed houst[emoji35]
mabe i damege an injector?
Skickat från min iPad med Tapatalk
Macrobb
North Idaho
Have you verified the pressure coming out of your duralift both at idle and when driving?
I'm assuming you are saying a "squeezed hose"... a crushed rubber fuel line?
If it /is/ a crushed fuel line, the question is how did it get that way? The IP should /never/ be able to draw enough of a vacuum against a hose to crush it, unless the line is blocked somewhere(like in the tank).
Not from low pressure(the injectors only open at a certain PSI - 1400-1800 depending on wear), but if you got crud in there maby.
Honestly, if you need new injectors, I'd go with idiperformance.com. Shipping may be more depending on where you are, but you'll get a high quality pressure matched set.
blakken
sweden
the rubber hose whas squeezed betwen vacuumpump bolt and engine!
yes have check psi running never under 6.
Justin at idiperformance.com has a good reputation here. Typ4 does a good job with injectors. I have personally bought some injectors from Mel (Agnem) at Conestoga Diesel and am happy with them.
blakken
sweden
i just ordered new injectors.
when i come home from work i notised a dieselfuel leak under truck....it is a fuel line nut on pump that leaks.
if a fuel leaks whats effects is it on injector...can it knock on acceleration????
blakken
sweden
it was not the fuel line. it was the little screw ho sits betwen the 2 injection lines on top on ip head.
what is this screw for? it gos true a little sqvare knobb
plywood
Recovered N/A
Portland Oregon
It's for keeping the fuel in Lol.
Maybe a torque screw or something.
Probably a bad o-ring in there. Some don't like to be turned after sitting. Could have got ate by fuel additives or bio.
blakken
sweden
i torque the screew and its al dry now. still waiting on the new injectors
Skickat från min iPhone med Tapatalk
blakken
sweden
now i have new injectors and its feels smother, when i removed old injectors i had just drove for 40miles and let it rest 30min. i hade 4wett 4dry injectors tipps. is this normal?
carrasco4712
US
290000kilomters
rebuilt pump new injectors delphi from pensacola diesel
but i whant stanadyne injectors but cant find them
There is a place out here that has good reviews. On a new IP and injectors. You can research them if you want. Anyone can chime in on their opinion or experience with diamond diesel.
Sent from my E6830 using Tapatalk
blakken
sweden
i have new ip a d new injectors now. runs fine.
just wounder if the old ones i remowed...ther where wett tips on 4 off them.
SixFourShanks08
Staff online
