i recently hade a problem with low fuel pressure! now i have a duralift so its god.
Have you verified the pressure coming out of your duralift both at idle and when driving?
its showed up to be a sqezed houst[emoji35]
I'm assuming you are saying a "squeezed hose"... a crushed rubber fuel line?
If it /is/ a crushed fuel line, the question is how did it get that way? The IP should /never/ be able to draw enough of a vacuum against a hose to crush it, unless the line is blocked somewhere(like in the tank).
mabe i damege an injector?
Not from low pressure(the injectors only open at a certain PSI - 1400-1800 depending on wear), but if you got crud in there maby.
Honestly, if you need new injectors, I'd go with idiperformance.com. Shipping may be more depending on where you are, but you'll get a high quality pressure matched set.
