Injector Line Clamps
The original OEM clamps fit perfectly if the lines are not bent out of shape. If the clamps won't fit, then bend the lines a little bit to make them fit. If you are running around with clamps missing, you are on borrowed time, the lines will crack and leak if you do not have them clamped. Ask me how I know.
If you are using the truck now, and have some clamps missing, the least I would do for now is get some vacuum tubing and cut short pieces and slit them down the side and slip them over the lines. And then take a wire tie and squeeze the lines together to each other where you can to stabilize them and try to keep them from cracking. These lines are not cheap.
