Injector info
Oledirtypearl86
Whitehall MT
Hey guys I know A guy that is a super talented machinest and mechanic and we werewere talking today about building a injector tester for 7.3 psd injectors my only issue is I'm not sure on all that goes on with them does anyone have a diagram of oil in fuel 8n and voltage
greenskeeper
PA
considering that they are hydraulic electric unit injectors i'm not sure you could build a "pop-tester" that would work on older "conventional" style injectors.
Oledirtypearl86
Whitehall MT
So I took him a injector core today and he mesuret it and the oring tolerances we ace plans on using a hyd pump for the oil and a spare 6.0 lift pump for the fuel inlet were still trying to figure the electronics on it
Oledirtypearl86
Whitehall MT
Me either I dropped off an injector so he could take some measurements and got a 2 hp Motor and a hyd pump that will do 3k psi and I dropped off a spare lift pump
