In need of Trans Tunnel!!
mbarry98
Sycamore,il,us
Looks like everything's falling into place for my C6 to Zf Swap, the last thing on the list is the "High Hump" Trans tunnel cover there are no junkyards in my area with any so I am searching around for one any help would be much appreciated!!!
Koch13351
SoCal
I'm assuming a gas ZF tunnel would be the same as the diesel? I saw a 91 F250 460/ZF in a junkyard near me a week ago...
Good lord ........hqve at least 3 in stock but shipping would sooooo suck for 45 buck part....
Am I that much of a horder....holeee shitzkies...maybe ex was onta sumptin
mbarry98
Sycamore,il,us
I looked under my carpet and my whole floor pan is one solid piece is this normal for a cab with an auto trans from the factory?
if there is no cover plate, you should have an outline of where to cut stamped into the metal.
mbarry98
Sycamore,il,us
I do, so do I cut that out and drill holes for the cover and install it correct? I know it will need to be high for clearance.
save yourself the misery on drilling out the attachment holes beforehand, get the plate first, put it down over the hole and use it as an index. that way you are 100% sure there are no errors.
mbarry98
Sycamore,il,us
Thats what I'm planning on doing the trans is still 4 weeks out from being finished so that's why I'm trying to find a cover close to me.
JU57US
