In Need Of A Little Powerstroke Advice
BED BOLTS
sandy, oregon
I am also looking to change out my injector and ip. My truck is 2000 f-350 ford, what would you guy recommend!
streaker
lost
streaker do you run wmo? if you do what your mix and do you have any problems! or do you know anyone on the form i can talk to? yes i do run a scmt on the low setting.
thanks
If you haven't been down there yet, you might check out the biodiesel section, might have a better chance to get some of your questions answered.
milner351
SE Michigan
I've seen several folks on the old TDS board use a coat hanger down the dip stick tube to hold the inside part from falling in while replacing that seal.
I had an '88 IDI - they are good dependable simple trucks that run a long time, but, it's really tough to beat the power and torque of the 7.3 powerstroke!
Lance
