ericwade381
Egggh I should have left that old column in it started fine with pair of pliers lol. A wire came out of the column plug hit the metal of the column i saw some smoke at the solinoid, now no glow plugs coming on and no power at the key. Is there a fuse I could check for ignition I just put a new fender mounted starter relay in hoping that was it but nope? Could it be a issue with the gray plug on the column? I also put my ignition switch on my column rod from my old column ans nothing? Lost on this
