Ignition Lock Cylinder problem
catodd
College Station/Tx
Installed new lock cylinder from Autozone, now key will not come out. Truck starts ok....should i go buy another?
RacingSTude
Columbia, SC
Oh fer.... Naw, just leave the truck in the Walmart parking lot like that and somebody WILL take care of it for ya... ;Sweet :rotflmao cookoo
emmer
Canada
W :confused::confused::confused: T :confused::confused::confused::confused: F?
Sure Id take it back and try another, my lock cyl is screwed too.
sassyrel
iowa
your either not getting it in quite right--or something is really wore inside there--
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
is the cylinder all the way in the Column? or is the key not all the way turned back, or did you turn it back to far to the Acc postition?
subway
be nice to the admin :D
York PA
the lock cylinders from auto zone are less than impressive. i had one in my truck for a week before it started giving me a fit. i promptly pulled it and replaced it with one from napa, about twice it much but it was several years ago and it has worked flawlessly since i put it in. not being able to start the truck when it is 20 deg out with the family in the truck is not cool.
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
The one i picked up this weekend was from a local family run place and it was a standard one, the PN is US-70L IIRC
catodd
College Station/Tx
Well after foolin with it a little, she now works. The Ford ignition cylinder came with door locks too.....do i need to pull the door panels to install?
sassyrel
iowa
no!! not if your articulate--pull the spring clip that holds it in--pull lock--then you will see the plastic clip that holds the rod to it--now--get a small wire--and tie it around that rod below the clip twice--just believe me--pry the clip loose carefully--then hook the new one up,lock in,clip in--if you drop the rod--dont blame me--:rotflmao:rotflmao
