TwoTone IDI
ZF swap completed!
i recently swapped out my automatic steering column for a manual column. i found one from the same trim level and model year truck but the ignition cylinder had been removed, which was totally fine, because i wanted a new one from advance.
however this brand new lock cylinder does NOT spring back from the "start" position when you release it. it just stays there.
would that be an issue with the lock cylinder itself or my column?
ive perused alldata, other sites, and the internet and not found anything really describing how that whole system is supposed to work.
