Idit piston rings
frankenwrench
overkill is under rated!
Weatherford tx
I read through a large amount of the tech article and found part numbers for the na rings but didn't find a part number for the std idit piston rings. Any clues?
Philip1
Northeastern Nevada
As far as I'm aware the piston rings are the same between the idi and idit. Someone with more knowledge than myself might correct me but I'm pretty sure only the wrist pin (and related parts) are different
Sent from my SM-G975U using Tapatalk
u2slow
bilge rat
Coastal BC
The factory IDIT uses keystone shaped rings. They are self-cleaning, and seal better to deal with the higher cylinder pressures of turbocharging. You find this design in most industrial diesel engines.
Thewespaul
Bulverde, Texas
The na IDI rings are not keystone like the idit rings, here’s some specs on the various IDI rings.
IDIT rings top to bottom:
1/8” 6* keystone
5/64” 3* keystone
9/64 oil control ring
1994-1989 na 7.3:
1/8” conventional
5/64” conventional
9/64” oil control
The 88 7.3 is 5/64, 5/64, 9/64 and the 6.9 is even smaller at 5/64, 5/64 and 7/64.
Garbage_Mechan
Garbage Mechanic
Central Cal Foothills
Thanks for clearing that up Wes. I looked at some pistons this morning before I found your posts. I guess I’m just used to diesels having keystone rings. The first diesel I ever rebuilt, a Waukesha 190 DLC had them. But the 6.9 piston I have on my bench doesn’t. Guess I shouldn’t post from the campfire lol.
Thewespaul
Bulverde, Texas
Wasn’t my intention to “internet correct” anyone haha, just sharing what I’ve found. Really any diesel should have keystone rings, just another reason to build an idit over the older idis.
Garbage_Mechan
Garbage Mechanic
No need for you to apologize Wes, I was the the one talking without checking facts first. Glad you are here with fact checked info.
thamojster
