IDIT piston pin bushing
jwsfarrier
Molalla,OR
I have a set of turbo rods I will be fitting up with new pistons and would like to change out the all the bushings. Everything I come across is for NA application. I know the OEM turbo pistons have a bigger pin diameter but none of the sites I searched differentiated between the NA and Turbo applications. If someone in our great pool of knowledge could turn me on to a source or part number it would be much appreciated. Cheers!
Randy Bush
Great Falls, Mt
You do realize that when installing new bushing a machine shop will have to size them to the pins. I would take the rods to a machine shop and have the check both ends of the rods to see if they are out of specs before just spending the money on new.
jwsfarrier
Molalla,OR
Thanks for the heads up. I don't know the history of the rods as I bought them used,and not all the rods are from one motor. Good idea to have them spec'd out to make sure though
typ4
Newberg,OR
The guys that are surfacing the heads can do the rods and get the bushings
