Idi to power stroke
mow4682
Hi guys, I have a 93 f350 that I swapped from duly to singles, and I wasn't o replace the 7.3 idi with a 7.3 power stroke. I know that I will need a new harness, but do I need to change anything with the frame? Thanks
Sent from my XT1080 using Tapatalk
Sycostang67
Scooty Puff Junior
Kuna, ID
Pretty sure you will need at least all the wiring for the engine, the dash and the instrument cluster itself.
mow4682
Sweet thanks guys, this beast should be an easy swap considering I have all the dash and harness stuff
cpdenton
Truck needs paint.
Conway AR
I think you need the gas pedal too. Seems like the strokes are drive by wire....
metrojd
Pittsburgh,Pa
I did my CC
Need all under hood wiring and IDM , dash wiring,PCM and bracket throttle pedal.
When I did mine I put the power stroke and Radiator brackets in, overflow and washer bottle
I used a 96 wiring in my 93.
Had to change a few pins in the connector for the back lights.
chris142
SoCal
how do you guys figure the electrical out so easily? id never even try this swap myself
Electrical side is pretty easy.
And there's always somebody that has to get butthurt about the idi.
Sent from my SM-G900R4 using Tapatalk
ToughOldFord
The Cold Glow-Plug
City of Shasta Lake, Ca.
Electrical side is pretty is.
pretty is?
No need to get butthurt Jasper, some guys just can't read the writing on the wall. If they want to butcher their trucks let them, we'll still know better. ;Sweet
oregon96psd
Kuna, ID
I wouldn't either, there's no point whatsoever in down-grading.
If I ever get mine to the point where the body work is done, the next step is to get rid of the idi, worst thing about the pickup is under the hood. Which really sucks cause I like the 80-86 body style.
Hmmm.
Fixed.
Personally, I love my powerstroke over the idi's.
Cheaper to make high levels of power with.
Easier to diagnose. Just hook the Ole AE, and wham bam thank you ma'am, here's your problem.
Not saying I wouldn't own another idi, but I'm happier with the psd.
Yeah injectors are way more, but they last a lot longer.
mow4682
Thanks guys, I worked 17 hours non stop yesterday, all night actually, and got it in! I'm doing the wiring as we speak.
