IDI Parts
Kevo1288
Worcester MA
$50 plus shipping
Alright Wes , putting together a list of stuff. Was thinking about picking one up to port match and searching for a set of heads from somewhere to port and rebuild over the winter so I can get a head start on my engine build for next summer when I can rock the summer ride and park the truck for a bit.
Thewespaul
Bulverde, Texas
I’ve got plenty, but I really don’t like shipping them. If I were you I’d keep an eye out for a parts engine you can pick up cheap
Alwaysreadyrob
2002 7.3 POWERSTROKE 4x4
OAKHURST CA
wes, I need the fuel filter head also if you have an extra one lying around and also the dipstick bracket that holds the trans dip stick in place it bolts onto the valve cover bolts on passenger side ya ?
and also need the glow plug controller cover.
get back to me with what you have and a price list please.
Thewespaul
Bulverde, Texas
Is this the bracket you are referring to? The oil dipstick and trans dipstick bolt on separately, the trans bracket is welded onto the trans dipstick tube and bolts to the bottom of the valve cover, where the oil dipstick bolts to the top of the valve cover like pictured here
I should have everything else you need, just need to dig around and clean them up.
Thewespaul
Bulverde, Texas
I’ll dig around, did yours fail the tests or is it just peace of mind want to get a known good one? I’ll likely have to disassemble another core if I don’t have one on the shelf if you want a used factory one, or I can get a rebuilt oem unit.
WarNose
Bay Area, CA
The motor was dropped while I was buying it. The guy was loading it into my truck when his rigging failed. The motor fell about 3 or 4 feet and hit the ground. I spent so much time inspecting the block and crank for damage that I never looked at the oil pump. Well the front gear got bent, probably the shaft too. Luckily it didn't fall while it was over my truck.
Don't bother tearing a core apart if you don't have one on the shelf. How much for a rebuilt oem? How soon can you get one?
Thanks.
