IDI Headstud Part Numbers
The bulk 7 inch studs for the 7.3 are
AR 7.000-1LB
Nuts are ARN 12-1
Washers are ARW 78 N
I don't have the numbers for the actual kit they make for our 7.3 idi engine. I recall the stud length was 6.75 inches or really close to that...
wmoguy
Colorado
I'm curious, these longer "bulk studs" could they safely be cut down w/o the risk of being heated up and damaging them
wmoguy
Colorado
they dont need to be cut.
right, isn't there like very minimal clearances with those bulk studs? My worry is my heads have been shaved. Not shaved in the sense of how it's typically used, by they were trimmed to make sure we had a nice flat surface before reinstalling. I'd hate to have it tore apart to put in these bulk studs only to find out I have a clearance issue because my geometry has changed slightly
typ4
Newberg,OR
The only place they even come close is the rocker locating bridge, if the block threads are clean and the studs all the way in, the most would be sanding off like 2 threads, and it has to come off the top because the stud shank bottoms in the recess in the block.
wmoguy
Colorado
thx Russ. What is the $$ on these bulk studs from you again? You can PM me the price if you prefer
typ4
Newberg,OR
checked yesterday, 410.00 with 6pt nuts.
wmoguy
Colorado
k thx. and readily available? I'll ping ya when I get back from this huntin trip to order.
Question: in your experience, you think I could get away with installing 1 stud at a time w/ the heads on and motor in the truck?
34 studs per engine.. Replacing one head bolt with a stud has been done and no issues but. Its not the correct way of doing it. Think of all the stress on the head plus you will have many clearance issues leaving the engine in the truck. I know what its like to work alone pulling or installing these engines. I work alone all the time. I installed and removed my engine 5 times one day. The torque converter pilot was interfering with the crank spacer. I opened it up 1 1/2 thousands then it fit.
placidoert
