IDI Body Mount Replacement
hesutton
The Anti-Anderson
Bowling Green, KY
Thanks for sharing this Heath!!!!!
This is defenentlly gonna be a very usefull thread to all of us!
You're welcome. I don't know if it is Tech worthy, but I will reference folks to this thread when questions come up in the future about these mounts.
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
Ahhh another light goes off. I now assume Ron used the puck with the mount to gain added height...Damn I need more coffee this morning.
Joe, I think you are right. Ron used the pucks to lift the body and inch or so. He put them on top of the stock mounts.
Heath
trackspeeder
Stone crusher.
North Branford. CT
Heath
It should be "tech worthy". Good write up for somebody who want to tackle this kind of project.
I will admit, I cheated. Sawzall is your friend.:D Chop out the hardware and replace with new. LOL
MIDNIGHT RIDER
It should be "tech worthy".AGREED !!! Good write up for somebody who want to tackle this kind of project.
I was wondering about that.
Where, pray tell, does one acquire these new sleeve-thingies ??
Thanks. :)
Jbevs
IDI Newb
IL
I have seen guys make them for rangers by welding pipe to a washer. Other than that I have no idea.
RLDSL
Diesel fuel abuser
Arkansas
I just used some monster fender washers I got at Ace hardware and some threaded rod for those rear cab setups . I had to take a sawzall to mine as well, even a 1" drive IR impact wouldn't budge those suckers. BEtween the washers and the hockey pucks the whole setup went back together nicely ;Sweet Much needed extra turbo clearance
hesutton
The Anti-Anderson
Bowling Green, KY
Thanks guys. It was my pleasure. I was most annoyed by the driver's rear mount as the tank made the whole procedure a huge PITA. The other mounts were less of a struggle. If I had the not tried to use the grade 5 hardware the 1st time, I would have saved some time and aggravation.
Mel, or whoever, just let me know what I need to do or change if this is to be added to the Tech Section and I'll be happy to do so.
Heath
Great write up heath, I have the blacks with 60k on them, no noise ever.I used an axle nut socket as a puller to remove the front cab mounts , put a long gr 8 bolt in the rear from the top after soaking and hit with a big sledge, figured it would takemany whacks to remove, one did it. I like your puller, thin and functional
The sleeves do not need to be pressed back in , that swadgeing procedure was to keep the mounts from falling out of the frame at the factory when they rolled it all around, upside down, I saw pics once , cant remember where.
hesutton
The Anti-Anderson
Bowling Green, KY
Thanks Russ. It is good to hear the black poly body mounts are quiet. A BFH works for a lot of things. LOL I agree with not needing to press the sleeves back together. I did remove that flair so the two halfs would slide together easily.
Heath
hesutton
The Anti-Anderson
Bowling Green, KY
One other thing I will point out; the front fuel-tank interference must be a crew-cab thing, and possibly an extended-cab.
I don't remember the fuel-tank even being anywhere close on my standard-cab. ;Sweet
Damon, I had a look under my regular cab F250, and it is the same as the crew cab. The front tank blocks access to the driver's side rear cab mount. Sorry.
Heath
leojr
Denton, TX
I did the Energy Suspension body bushing swap a few months ago but noticed that my driver's side cab is now about 1/2" high! Both sides of the cab were low and now the passenger's side is perfect but the driver's side is high. Did anyone else have this problem and were you able to resolve it?
Mikerson
Moscow/ID
Heath
Thanks for the nice write-up Heath. Your posts saved me a lot of time. I just did this myself and found that the metal sleeves on mine were metric thread (M12x1.75). Could be the reason you were breaking your all thread. I had no problems using my factory bolts to remove the mounts. Just get the exhaust pipe and washers, stuff the assembled puller in there, and go to town with the factory bolt and an impact wrench. Just adding this information so the next guy knows!
-Mike
JU57US
