if it doesn't have the adjustable clutch master pushrod (most '87 and up did asway with them) there is no adjustment.
check your bushings in the bracket.
Just go out and look for an adjustable clutch rod in an older for in the juckyard. I found one and put it on my truck not to long ago, it helped tremendously. I also just found a second one that I'm planning on cleaning up and swapping in in the near future. The old one isnt round on the end, it looks more like an egg.
I believe the first on came out of an 83 4sp, while the other came out of a 91 f150 5sp.
I have found one at NAPA, but it will have to be modified. There's not much room at the Master Cylinder. It seems to me that I will have to put 1/2 - 1" of steel bushings behind the Master Cylinder to give me enough room to fit the adjuster in.
