I have my heart set on a mechanical clutch linkages how to hook it up?
GTFD
San Diego Ca
JRED, thanks for clearing up the all external for me, I've been having nightmares over that issue because i like manual trannys only; and still hunting for one.
suv7734
BC Canada
Diagrams of Mech. Linkage
JD,
Here are some good diagrams of the mechanical linkage referring to a 1981 model with gasser.
subway
be nice to the admin :D
York PA
yup that be the set up, i circled the pivot part that screws into the back of the block. mine didnt have a return spring either......
my pleasure to help GTFD and welcome to the site lots of helpful people here!
Diesel JD
Gainesville, FL
That doesn't look like it will screw into the t19 bell...its going to take some work. I'm up for it and in it :)
subway
York PA
JD, here is a quick mock up of what i have done in the past to not have to worry about the ends again.
1. the first part is the stock clutch rod complete with some wear on it:D
2. the secound part is the end cut off and tapped
3. the third and forth parts are the tie rod ends that can then be screwed on with a jamb nut. i prefer the forth style but dont always have the room for it.(dont forget to get right handed threads unless you have special left had dies for the threads)
hope this helps make things clear. just make sure the new center of the joint measures the same as the old joint represented by the line you see running through them. it really isent hard to do.
Ooowww somebody uses a 3D drafting package at work. ;Sweet SDRC?
subway
York PA
yup:D got professionally certified last year, its Solid works but we also have Pro-Engineer but its been so long I would have to re-learn it. great stuff though to do layouts with tolerances before anything is even built.:cool
funnyman06
Coventry, RI
YAY, Solidworks. I just took a class for solidworks, and i also use it alot. Its so nice to see a product before its ever made.
Diesel JD
Gainesville, FL
Thanks Jared those are some good pics. So you cut the bend off the linkage, then thread it with a die and then add that jam nut which threads into the tie rod end correct? Now all I have to do is get the engine pivot to fit the t19 bell or fabricate something that will(plus a spare). Thanks
subway
York PA
yup you got it, i just added the jamb nut to keep the linkage from rotating in or out of the joint by itself.
