I hate drum brakes
SkipBurney
Statesboro Georgia
Does anyone have an exploded diagram of the rear brakes. Mine had a sticking rear wheel cylinder so while I am doing everything else I am going through all 4 wheels. I learned as a kid to only pull one side at a time but when I pulled the drum off the left rear a broken spring fell out and I really dont want to open the right side till I have the left side done. I need to know which spring is broken so I can try to find a new one.
ps444mike
Southern Calif
Lol going thur the same here.. had two broken springs one on each side an a stuck drum :( ended up looking up on Google an typed in 1997 ford f350 drum brakes.. got a few different pics.. an saved onto my phone.both of mine were the long skinny springs they go from shoe to shoe below the axle
lotzagoodstuff
Carmel, IN
+1 on replacing all the springs with a hardware kit. The kits are relatively cheap and I can honestly say, there aren't that many things that look nicer per dollar than redone drum brakes with all new springs and hardware.
Spend the money: you deserve it :)
SkipBurney
Statesboro Georgia
Thats what broke on mine too
To add to my original comment, if you have an older semi floating rear end I would not rebuild them but upgrade to a stronger full floating rear end and rebuild those brakes instead.
Dirtleg
Cloverdale VA
Just realized that this is for a 1986 F250, don't know if they are the same between bull nose and brick nose but somebody should chime in.
Just to clarify my 93' F350 is setup exactly the same as this.
And yes get new spring kits Old springs lose their temper, stretch and break.
steve phillips
burnwell/ky
this would be a good time to replace steel and rubber brake line, completely to master cylinder. cu-nic line is the only way to go. amazon prices cant be beat on it and include all fittings you will need to go to master cylinder. i always do a complete brake system rebuild on any new idi i get. good piece of mind, especially if you tow. while your there check spring hangers for broken bolts, they happen. best of luck.
ps444mike
Southern Calif
I did order the replacement spring kit from rock auto.. well worth it like under ten dollars.. all the springs..
Black dawg
sw mt
Make sure you replace the self adjuster cables.....they are the most prone to failure part of those brakes
BrianV
Winchester, Ontario
Here's a screenshot from the 1988 shop manual, with both the F150 and heavy duty variants!
MadScientist
