HTT exhaust manifold ordered.
Whit
lost in Why-homing
I ordered one up for my 01, trying to optomize turbo effeciency , here are the details of the manifold. I plan to do port matching and polish it up before installation.
The new 3-piece pulse manifold - 1988-2002
*Made in USA
*12 and 24 valve styles - Port matched for each version.
*Tuned, balanced flow design.
*Nominal wall thickness .300"
*This manifold flows exhaust more evenly than the stock manifold and is not as prone to cracking.
*Comes drilled and tapped for a pyrometer (pipe plugs installed).
*Ships ASSEMBLED at no extra charge.
*Comes with necessary mounting bolts and heater hose bracket where required
A complete mounting kit (12 valve) (24 valve) is available. The kit includes:
Head to manifold gaskets
Manifold to turbo gasket
Turbo oil drain gasket
Turbo mounting studs
Turbo mounting bolts
Turbo mounting nuts
Here is a pic of the dude
TPCDrafting
Structural Steel
Wyoming, USA
Be sure to give us a full report on the SOP'o'meter and EGT differences. I'm curious what the real world differences are between this one and the ATS if there are any worth mentioning as far as performance goes. I do like that it comes pre-tapped for the pyro and pre-assembled as well. ;Sweet
lewisstevey7
