Howes lubricator / Diesel Treat
CDX825
filtration nut
Litchfield,Ohio
So then why not use both during the winter? The TCW3 for lubrication and the Howe's for antigel. I usually use Power Service for antigel, but that's because a guy gave me a couple of gallons a while back. I have some Howe's in the bed right now (easy access for use while fueling up) because I was in Menard's a few weeks back and they had some on the shelf. It was about 15*, the north wind was blowing pretty hard (20MPH+), and my Power Service was at home. I bought some Howe's just in case. Honestly, I rarely even put anything in my tank for antigel. If it's supposed to get below about 5*, then I will. Otherwise, the stuff that comes out of the pump is good enough for me. FYI I run Optilube Summertime blend for lubrication. I put both Howe's and Optilube in my tank while filling up before heading home.
Problem I was having was the 2 stroke oil was making the truck hard to start. Even with howes and 2 stroke oil it was temperamental. That was running at 1 ounce per gallon of two stroke oil.
Kevin 007
Full-floater
Nelson BC Canada
That's interesting. I don't believe that a ratio of 2 stroke oil such as that one, would cause hard starting problems. But stranger things have happened....I have been wrong before....lots!!!
HammerDown
Glenolden Pa
Absolutely zero starting issues when I used the two stroke oil one oz per gallon.
What I do notice...the engine (maybe injectors) seen a little quieter and some blue smoke under a harder acceleration and maybe on extended idle.
idiTravelAll
Gilbert, AZ
My input probably doesn't count (12 valve) but when using howes meaner kleaner I notice significantly less coal, would probably be great for anyone have opacity emissions issues.
CDX825
filtration nut
Litchfield,Ohio
Only noticeable when its really cold. During the warmer part of the year I have no issues and run two stroke oil religiously.
nelstomlinson
Delta Junction AK
I'm using a pint of two cycle oil per tank. Usually I put 12 to 14 gallons in per fill up, and a pint of two cycle, so that's a little over one ounce per gallon. I haven't had any problems with cold starts, even at -40. I do use a pint of Power Service white bottle along with it during the cold months.
Alleycat
