I started looking and found some good info. from what I have read so far you cant really decompress the motor much below 20.0:1 or 19.0:1
supper chargers fill the void of low compression
you might want to recheck your math.My 85 gets about 100mpg want to know my secret?
it just sits there I never drive it
I know right.you might want to recheck your math.
you can't do a MPG calc if you're not moving.
stupid HP numbers can be made. parts are available to do so.
UNTIL you are able to the heat generated by the head design of the IDI, will you be able to USE the HP you are making.
1/4 mile races are won with little regard to the heat generated.
a diesel makes it's living by pulling loads and keeping the generated heat into the cooling system down.
I'm happy with my low HP truck that places a heavy emphasis on cooling system heat management. I have yet to find a grade in the continental USA that stresses my cooling system where I had to pull over for the truck to cool down or had to scale back my power output to keep the heat under control.
making it home without roadside repairs or being towed is a major win in my book.
do yourself a favor and butter her up for one of those new alu radiators and an intercooler kit. i'm running 7psi post IC with a ATS 093 aftermarket kit. I drop it into 4th at the bottom of a 10% grade and casually keep an eye on the gauges. absolutely no need to glue an eyeball to any of them. coming off a hill, I follow the big rig speed limits when I have a 10k load bouncing around behind me. Drop down to 3rd let the compression braking do the work. occasionally hit the binders if a idiot cuts me off, so I have some space once again. easy.Good to know, I'm in a slow process of putting a turbo on mine now, and intend to pull a 5th wheel with it. I'm kinda nervous about the whole thing, as I've got a very easy going 'mission control' to answer to, but I hate screwing up.
I'd been wondering how it will do on grades, and heat.... When I had my 98 24 valve Cummins, and was pulling loads up grades, I'd have to slow down, or pull over as it seemed to overheat continually on decent grades.
