How to locate misfiring injector
slyhog022056
Grand Prairie, TX
97 F250 HD with 7.3 psd. I have a constant miss from one of my injectors. How can I trace it out electrically?
I swapped injectors with known good one and still have a miss. Do I need a oscilliscope to trace out the circuit? My high dollar scanner doesnt tell me anything.
Does anyone have a wiring diagram of the harness between the PCM and the injectors? I have looked and looked but to no avail.
Also having a problem with the ignition circuit. I can be driving along or sitting still and everything goes dead, like th key has been shut off. It fires right back up but at 80 MPH it is annoying as it sometimes does it 3 or 4 times in a mile stretch. Any clues? I have swithched the ignition switch and OHMed out the wires and terminals.
slyhog022056
Grand Prairie, TX
i need a diagram to know which wires are which. did a search and found 3 different descriptions as to which wire is which.
need to know if i am getting a pulse from pcm also.
i was getting 19 mpg then about 2 months ago it dropped to 14 mpg
Google search the gbreman website. They have a article with the idm wiring.
If it isn't already, unplug the fuel heater.
Are you losing all dash lights? Or is the engine shutting off and the dash stays on?
Sent from my SM-G988U using Tapatalk
this.
greenskeeper
PA
remove both valve covers
with the engine running look for equal amounts of oil coming from the spouts on each injector indicating they are all firing the same.
there should be no oil leaking from the top part of the injector
to disable an injector, unplug the two wire plug going to the injector....if the miss goes away you've found the problem cylinder
m2rtin
