Originally posted by Ramprat
Can's of Sea Foam do I need to get
Planning on replacing the fuel filter Sat & am going to fill up the filter housing with Sea Foam & then give both tanks the Sea Foam treatment
This had better work or somebody from Neckervill is going to be in hot water
/QUOTE]
WHO.................. ME;p
Rampy, I generally get 3 cans...............when you change out the fuel filter, get as much of the fuel out a s possible...either with a small turkey baster, or someting similiar.
Put the new filter in and then fill the bowl and filter full of the sea-foam.
Have you ever removed the regulator assy from the left side of the filter??????????....2 bolts-10mm socket.
Gently move away from the bowl and you will notice a thin "O" ring---DON'T LET IT fall into the valley of death
Some luck can be had by placing a piece of white cardstock under the area...
Use a Q-tip or similiar to remove the small-about dime size- screen from the filter bowl- you can see the port where this is-
the screen will prolly have a build-up of muck....clean this screen and re-install, paying careful attn to that little "O" ring.
I usually put 1 full can in each full tank..............
Hope this helps.....................BTW
