How can you tell?
Compu Doc
Middletown NJ
How can you tell the difference between a billet steel torque converter and a stamped steel torque converter when it is installed in the transmission and the transmission is installed in the vehicle looking at it with the inspection cover off.
'94IDITurbo7.3
HAMMER DOWN!
Fowlerville Michigan
If i remember from machining class. a billet piece of metal is a piece of metal that has been machinedd. ie lathe, mill.
So i guess if it looks like it has been machined then then it would be billet.
Brimmstone
The top covers look completely different. The stamped will be rounded while the edge of the billet will have a sharper square corner.
I don't have any pics but any torque converter sales info will have pics for you to compare each. They look completely differant. I have a BTS triple disc billet converter in my rig. Garrenteed not to rip rot stick stink tear or pull hair.:eek::angel:
Blind Driver2
New Albany, In
Billet is turned on a lathe. It'll be purdier and will appear to be much better quality.
I'm thinking the billet converter is aircraft aluminum?
ntjapkes
