Here you go guys..Clean on CL
jrad235
Vancouver, WA
http://eugene.craigslist.org/cto/4092570499.html
A pretty clean rig, maybe not overpriced if he has receipts for everything. I like the seats.
1992 ford f-250 ext cab 4x4 xlt 7.3 idi diesel, 5 speed manual.
zf-5 transmission, 4:10 gears in both axles manual floor shift 4x4, manual locking hubs,
higher miles on body 293,000, BUT...
NEW ENGINE INSTALLED on 2/17/2008 with 92,387 ORIGINAL miles on engine, odometer on this truck at change was 223,986 so new engine currently has 161,401 miles on it to this day,
brand new complete full set of heads installed on 10/16/2009 at 245,311 miles on truck, which is
113,312 on engine at time of replacement, head gaskets and studs, waterpump, thermostat, coolant and sca's added at the time also.
To make it easier from this point on i'm going to list all the new parts installed by what the mileage was on the truck odometer mileage, not the new engines mileage.....
New glow plug system: all 8 glow plugs replaced new motorcraft 2D-9
& and new glow plug controller BWD-GPR8 and also soldered new bullet connectors for all glow plug connections on 1/2/2010 at 246,795 miles
installed 55 watt fog lights in grill and removed "soup bowl" and installed new air cleaner assembly and fram CA3501 filter on 1/8/2010 at 247,142 miles
installed anco winter wiper blades, deer alerts in grill, slide out towing mirrors, blind spot mirrors on 1/16/2010 at 247,563 miles
changed oil chevron dello 400 oil filter napa 1742 new fuel filter Napa 3417, added diesel kleen to fuel filter at change on 2/21/2010 at 249,114 miles
front end alignment at hanson tires in klamath falls, or on 2/22/2010 at 249,140
installed brand new vacuum pump on 8/7/2010
replaced fuel filter, added aftermarket, electric aux fuel pump pulled front fuel tank and installed a new fuel pickup assembly on 9/5/2010 at 260,419 miles
oil and filter change using delo 400 and new larger 7.3 powerstroke filter holding additional quart and better filtration on 9/18/2010 at 261,000 miles
replaced air cleaner and wiper blades on 11/13/2010 at 263,491 miles
installed new aluminum steps and installed cab roof lights on 11/15/2010 at 263,754 miles
replaced both batteries with interstate MTP-65 WITH 85 month warranty (7 yr 1 month warranty) also replaced all positive battery cables on 11/26/2010 at 264,482 miles (battery cables only not including install) cost $135.58
oil and filter change replaced dipstick tube on 12/10/2010 at 266,399 miles
New H.I.D. headlight bulbs and ballasts (high and low beam) New clear headlight lenses, New clear front corner lights, turn/parking light lenses on 1/18/2011 at 268,718 miles
front and rear brake pads replaced and new coolant with sca diesel coolant additive replaced on 2/21/2011 at 268,983 miles
NEW high performance MOOSE brand injection pump and brand NEW delphi injectors and new o-rings and brand new steel fuel lines from pump to injectors, new braided fuel return lines, new napa fuel filter, and injection system professionally timed, everything was done at Bradley's Diesel in Klamath falls, or on 3/14/2011 at 269,522 miles ( cost lots of $$$$...)
oil filter & change 4/4/2011 at 270, 634 miles
installed new power window motor with warranty at napa part # 49-822 on 2/16/2012
replaced clutch linkage bushing and clutch push rod bushing with warranty at napa, on 6/16/2012
4 brand new tires bfg all-terrain 285/75/16 10 ply load range E at discount tire salem, or on 9/24/2012 at 260,452 miles
new drag link part # SPI-440-1075B, and had alignment done with camber bushings replaced at dean tire in Newport, or on 9/30/2012 at 260,987 miles
New performance suspension components. 3/4 ton to 1 ton leaf spring conversion done, brand new F-350 1 ton leaf springs leaf spring bushings and leaf spring perches / shackles installed front and rear installed at Jim Meyers racing products in lincoln city, oregon on 10/1/2012 at 261,022 miles
new serpentine belt, new air cleaner, changed oil and filter on 122/2013 at 288,448 miles
replaced front wheel bearing and hub assembly's on 1/26/13 at 288/448 miles
replaced u joints napa parts on 7/28/2013
new heavy duty clutch slave cylinder and new fluid and system bleed on 8/5/2013
rear axle service and new pinion bearing and pinion seals installed and 75w90 oil with limited slip additive done on 8/17/2013
ALSO I AM FORGETTING SOME OIL CHANGE PAPERS AND OTHER SMALL STUFF,
AND ALSO CAN SEE IF I CAN FIND THE MAINTENANCE LOG THAT WAS DONE ON THE NEW ENGINE THAT WAS DONE PRIOR TO SWAP AS IT WAS METICULOUSLY MAINTAINED AND HAD VERY LOW MILEAGE, MAINTENANCE LOG ON THAT WAS AS THICK AS A BOOK!
TRUCK HAS: power windows, power locks, a/c, keyless entry with remote. cruise control, tilt, abs brakes, power leather lariat seats with center console out of 2002 superduty, drivers seat bottom has some tears though, cloth back seat, hid headlights with ballasts, projector headlight and parking light lenses, dual fuel tanks, front and rear tow package, electric trailer brake controller, has hidden fold down goose neck hitch in bed $$ triple aftermarket gauges, cd mp3 player, premium sound, alloy wheels, wide tires, overhead cab lights, truck steps, roof mounted cb,
runs and drives good, starts right up with no issues, reliable, good mpg, have a new clutch, pressure plate, throw out bearing, and etc that goes with it to install down the road whenever it will need it. , passenger power window motor needs replaced. $20 part, not abused, built to tow, this is fast and has a lot of power for a non turbo idi, will keep up with stock powerstroke with the performance fuel mods that were done. manual trans, and low mileage engine, and is more reliable and parts and maintenance is way cheaper than a powerstroke. cheap on insurance $40 / mo for full coverage, truck has new tags and title is clean. never been in a wreck, feel free to carfax it! not a show truck so don't expect it to look like a brand new $50,000 truck, but it is a very clean for a 4x4 diesel its age. AND VERY WELL MAINTAINED,
blue book value is $5,781 good cond. private party not including several grand in work that has been done to it. due to work done. I want to make this very clear, my price is pretty firm . price reflects it's few flaws, mainly normal interior wear from it's age BUT OVERALL YOU WONT FIND A DIESEL THIS WELL MAINTAINED WITH A LOW MILEAGE ENGINE AND ALL NEW PARTS... if you know these trucks and whats been done to it and the costs involved then you know its a good price and good to go forever. $5,500 CASH,
Wyreth
Certifiable Noob
Las Vegas, Nv
Guessing that's actually a baby moose.
Documentation on the truck, AND the replacement engine.. That's seriously impressive. I wouldn't feel bad paying the asking price.
Nanohawk
