It has been a while since i have been on here, but i knew this would be the place to come with the problem that i am having with my truck.
I have been having issues with heater coils leaking. I have replaced 5 in the last 6 months. I knew my head gaskets were leaking , so i figured that was the cause of the system over pressurizing and taking out the cores. So i redid the head gaskets, about a month ago , and the system is still over pressurizing to the point that the radiator is starting to leak on the sauter joints . What other issues can cause the system to over pressurize other then cavitation? Also when I replaced the head gaskets, I replaced the thermostat and water pump.
could a stopped up radiator cause these issues?
