Help with steering torque specs
stumiister
Diesel Truck Tech
Stockton, California
Im replacing all the innner and outer tie rod ends and the adjusting sleeves, I tried to search for the torque specs but couldnt find any, help please and I cant go home until I finish thanks.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
That's something I have never torqued. A 7/8 wrench can muster up plenty of torque, don't make them crazy tight. I go just past snug then to the next hole that the cotter pin will align with.
lotzagoodstuff
Carmel, IN
Good and tight, to the hole that lines up closest, with the cotter pins in place they can't fall off.
Don't worry: they won't fall off, think about how much force it took you to get the old ones to come off the taper.
stumiister
Diesel Truck Tech
Actually the nuts themselves werent very tight but it took a few good hits with my BFH to get them to come off the spindles and pitman arm, however I did find a torque spec for the tie rod ends it was listed at 65ftlbs but didnt find anything for the inner tie rod ends or the adjusting sleeves.
Alleycat
