jfp3205
new ford 7.3 owner
Ok, Here is my problem. I had a local transmission shop rebuild my EOD transmission. Two weeks aga it stated to creep in drive and would stall in reverse. The shop replaced the valve body but then found metal so they rebuild the transmission again.
It seemed ok at first but before the transmission was replaced, the truck would sit still in gear until you gave it throttle and I assumed it was because the truck is so heavy.
Now after this rebuild, when you put the truck in gear, it takes off. The RPMs on the tach are between 500-750 so i do not think the truck is idled too high.
Can someone tell me what my problem might be so I can go back to the shop and not have them tell me that is normal. I do not like for the truck to take off like this so am I missing something?
Thanks
Thanks
