HELP Vacuum and brake problems
rodymartin
north wet
Ok now I have a new to me IDI with a problem.
The truck is a 1992 1/2 with serpintine belt 5 speed.
The problem is the ABS light keeps coming on and lately when I first drive the truck the brake pedal feels as if there is no boost until I go about 10 miles.
I have checked the Vacuum. It reads 15 at the pump. But as soon as the brakes are aplied the vacuum goes to 11 or less.
I have blocked off the brake line it does not bring up the vacuum.
I am begining to think the pump is bad.
HELP this is my daily driver
Mulochico
Modesto, Ca
My ABS light is on most of the time. A mechanic I trust told me it is more than likely the sending unit on the rear end. I do not have the pedal problems though.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
The vacum pump should pull at least 21 think the manual says 23 but it should do it within a few seconds of fire up i think you are right, the pump is bad.
gatorman21218
Ashland VA
take off the belt and try to spin the pulley. if it spins without much resistance than the pump is definantly bad. A new pump from napa cost me around 100 bucks and i had to buy the pulley puller to gut the pulley off of the pump.
Lance
Staff online
