I am a fairly new IDI owner and went through the same concerns, worry, anxiety about 3 months ago when I got my truck. After reading and fretting and getting over concerned, had a member here finally say "just do it". Ended up not being much of an issue at all. I tested all mine with the Ohm meter and found I still had 3 that were good. I soaked them all for a day or so with PB, then started with the good ones so I would get a feel for the process, sprayed PB on the threads as I went, turned them in and out if there was any sign of hangups. I used a 6 point 1/4 inch drive set to get them all out. All of mine had what looked like "slag" adhered to the sides and a couple were a little shorter than others due to burnt tips. The slag made turning out more difficult but the PB or WD will help with that. You may also want to go to a manual button to control the GP's in the future. I fought doing that since I wanted it to be "stock and automatic" - however - I made the change - clearly the ability to have complete control with a button is the way to go IMO. Just Do IT ! ! !
