jim_22
Well I think I know what has to be done but I am still stuck. The truck has been starting and running good except for one thing which I will mention in a bit. Yesterday I decided to tackle my non-functional 6-way ******* fuel selector valve and replace rotting leaking metal fuel lines under the truck. Now I can't start it after many hours of frustration last night. The last test I did was to remove the line from the lift pump to see if I had fuel squirting out when I cranked. I did not. Does this mean for sure that my lift pump took a sh*t? The pump is only two years old and has seen only a few thousand miles. Now for the suspicion. Two days ago my fuel filter light came on, indicating low fuel pressure. I replaced the filter with a new one and the light did not go out. The truck still started without hesitation and ran very well at all speeds. Was my lift pump starting to become weak? In retrospect I regret taking the fuel lines apart before solving the filter light.
Now, if I decide to go electric and bypass the mechanical pump it seems to me I need to do something to disable the mechanical pump but I can't seem to find the thread now.
And a side question, the return lines (one from each side are "T'd"). Does this T contain a checkvalve so the orientation of connection matters?
As always, thanks so much for those that take the time to reply.
