Help please, 2002 7.3 convert to a 6.0 frontend
jdphish
Mississippi
Above you can see the ratchet strap used to pull panel into alignment.
Very Ugly, but effective (I hope) stick welds from my little Campbell Hausfield 115V welder. Rods are 1/16" Lincoln E6013. High setting blew thru, low seemed fine but harder to start.
Started raining so decided to post this as a how not to weld body panels.
jdphish
Mississippi
Worst welding ever:(
jdphish
Mississippi
The other side is tacked in. Held without the clamps. More to do... thanks for looking.
jdphish
Mississippi
After a long absence I have been working on this truck. I have all the mechanical things complete.... almost. With new batteries the truck cranked up and drove with no problems after sitting for a year and a half.
jdphish
Mississippi
Here's the problem. Its leaking transmission fluid from or near the radiator. I am not sure exactly whats happening. Actually the first radiator I installed was bent from shipping. I thought thats why it was leaking. I just installed a new radiator from O'reilly's and its still leaking. Now, I am thinking the radiator may ne fine its a leaking hose. I am unable to see it happen and I have no help. Any sure way to figure it out with out buying all new parts?
Thanks for any and all advice.
jdphish
Mississippi
The reason I quit working on the truck is that my dad had a heart attack and had to have quadruple bypass surgery. Surgery did not go well. I have been out of state helping my folks during a rough recovery for my dad. Thanks
You see that small exchanger up front, the one that's tilted? That's the power steering cooler. Is it coming from that?
jdphish
Mississippi
I found the problem and now have a spare radiator. I punctured the hose going to the new transmission fluid cooler. Fixed now! Thanks all!!
It was the lower back hose. I had hard time getting it off old cooler. Guess I punctured it.
jdphish
Mississippi
79jasper, thank you, thats where I first thought the leak was from, power steering cooler. I did reroute the hoses. Now they go under the radiator support bracket.
jdphish
Mississippi
Here are some progress shots after I replaced the leaking hose...
Bottom pic first, top pic is second, last is middle pic with lights on.
It only needs a front bumper, which I plan to make later. I drove it to town and got fuel with no problems.
Nanohawk
