Heating wvo/mixing with additive
Exekiel69
That I can do too, but still don't know what type of heater I can adapt inside the tank, I have the idea of one like the block heater, but then again could this heat to the point it could burn? :eek:
93turbo_animal
Marengo,Ohio
hey EZ if you know what an electric water heater element looks like thats what I got except its 12volt its 7 inches long with 1" pipe threads the only bad thing is it can burn out like a water heater element if its run dry. EZ for summer use your design should work great for winter though I don't know if thats still enough heat I don't know how efficient those heat exchangers and filters are but I bet that heat exchanger would probably be the best but anything more then probably 20% veggie your going to need heated fuel lines
93turbo_animal
Marengo,Ohio
No EZ a block heater won't get hot enough to burn the veggy it takes like 400 degs to ignite with no flame your block heater will only be about 125 degs
Alleycat
