Pino2234
Has anyone done this mod? How does it work? My major concern is: does the forced low beam switch(when high beam are on so are the low beams) really make a difference?
The LMC harness is somethin else....why sell a harness kit with relays that aren't readily available any damn where?
One more fact; with genuine full-voltage lights, good old Sylvania Silver Stars will barely last a week; however, during their short life, they will really reach on out there.
For longer bulb life, I down-graded one notch and get far longer bulb life.[/B]
I built my own head-light relay system and gained DRAMATIC increases in light.
I went from barely 9-volts at the bulbs to full alternator voltage of about 14.5-volts.
I can see plumb into the next county.
I have a toggle-switch that will combine BRIGHTs and DIMs together, and it WILL make for even brighter lights; however, like already stated, the increased heat inside the bulb spells quick death for the elements.
Is this concerning the relay mod or the switch for highs and lows?
