Header paint on Turbo?
homelessduck
While everything is apart I want to toss some paint on the turbo, manifolds,etc. Will regular high temp. header paint handle the heat from the turbo? I'm not sure exactly how hot they get, but I know they get pretty hot!
Thanks.
-Dallas
dyoung14
Is getting worn out
spencer,tn
Thanks.
-Dallas
As long as it will atleast stand 1200 degrees
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
FWIW I tried doing that with my exhaust manifolds and with my turbo exhaust housing. I'm not sure if I didn't prep it right or what, but the paint didn't last long....it's been flaking off pretty steadily, and now looks almost as if I left it bare.
Not sure what I did wrong (if anything), but FWIW...
RyanDamo
1 IDI 2 Strokes
Shelton CT
if theres rust on it already it wont stick at all, go over it lightly with some sand paper then take like a paper towel thats wet with brake cleaner and wipe it down really good
idiabuse
Princeton Fl
I ceramic coated my turbo housing, exhaust manifolds, turbo manifold and the y pipe, once.
never will peel off and the benifit is more contained heat, improving performance.
Javier
The Warden
MiB Impersonator
I went a step further...went over the parts quite thoroughly with a wire wheel and wiped down with paint thinner and allowed them to dry out before painting...
Is ceramic coating a DIY?
MIDNIGHT RIDER
Until now, I never had much success with so-called Hi-Heat or Header paints; most would be gone after the first trip.
So far, my last experiment has done quite well.
I wire-wheeled and paint-thinner cleaned an exhaust manifold that was NOT ON THE ENGINE.
The paint I used was flat red VHT Flame-Proof Silica-Ceramic Coating 1300-2000*F
I put on several coats.
I did not "bake" it as was recommended.
However, and this may have been partial to my success, it was several days, maybe even weeks, before I bolted the manifold on the engine.
The first few trips, there was this highly disagreeable poisonous chemical odor that permeated the cab; plus, the manifold smoked enough that one would have thought that I had an engine fire.
The smoking has quit and the poisonous smell has all but went away --- or I am just becoming used to it. :rolleyes:
The manifold actually looks better now than when first painted. ;Sweet
By the way, the turbo gets no hotter than the manifold, so whatever will work on the manifold will also work likewise for the turbo.
Diesel_brad
Dunce
gilbert pa
I used a Product from EASTWOOD on my 83 manifolds. It was like the day i put it on 4 years latter and that was a couple of harsh winters.
They reccomend sandblast and then "bake" on(by putting on your vehicle and running it within 24 hours)
I did sand blast, heated with a torch, then painted . Didin't put manifolds back on truck for about a month, but they looked great.
here is a link. I used the silver stuff
http://search.eastwood.com/search?asug=manifold&w=manifold+paint&p=Q&ts=custom
