Header crack -- JB Weld?
Discussion in '6.9L IH & 7.3L IDI Diesels' started by cscmc1, Jun 28, 2006.
  1. cscmc1
    cscmc1 Full Access Member
    102
    Mar 15, 2006
    Manifold crack -- JB Weld?
    Found a crack in my pass side header (edit: MANIFOLD) the other day... I don't so much mind it as it's not too noisy yet, but I ought to try and plug it to keep the exhaust out from under the hood. Anyone used JB Weld or any other product on manifolds before? I'll look for a replacement at some point, but I'd like a short(er)-term fix now.
    Thanks!
    Chris
  2. dbarilow
    dbarilow over worked
    38
    353
    Oct 15, 2005
    Abingdon MD
    I dont think jb weld will stand up
    Properties (psi)
    Tensile Strength: 3960
    Adhesion: 1800
    Flex Strength: 7320
    Tensile Lap Shear: 1040
    Shrinkage: 0.0%
    Resistant to: 500° F
    Mechanics -- you can use J-B WELD with confidence. It is designed for safe, reliable, permanent repairs in engine compartments and heated environments up to 500° F. It's strong as steel and impervious to water, gasoline, chemicals, and acids. Working with J-B WELD is quick, easy, and convenient -- and saves you time, work, and money!
    I once picked up a exhaust repair putty to fill in some holes in my wifes old car that worked well it was called muffler mender by Victor products http://www.victorautomotive.net/pdfs/vic/ver1.pdf
  3. cscmc1
    102
    Mar 15, 2006
    Thanks for the advice! I actually hav a tube of muffler mender in the garage... I just thought I'd read somewhere that JB Weld (or something like it) was the cat's meow for exhaust work, to include manifold cracks. Obviously, at 500 degrees heat resistance that might not be the best choice.
  4. Mr_Roboto
    Mr_Roboto Full Access Member
    1,721
    Dec 23, 2005
    Elyria, near Cleveland Ohio
    I'll assume you are talking about an iron exhaust "manifold" which is different than a steel header.
    Iron can be welded with a stick welder and special rod for iron. I did a GM I4 manifold that was cracked so bad it was in about 15 pieces. I welded what I could reach in place, then unbolted it and welded the backside. Had I just unbolted it, it would have just fallen apart.
  5. tonkadoctor
    tonkadoctor Full Access Member
    3,776
    May 5, 2006
    none ya bidnes
    :rotflmao :rotflmao :rotflmao
    Having been a professional mechanic I would never even think of using some stuff like that on a customers car. There is a right and wrong way to fix stuff and those miracle cures are just wrong.
    Welding a crack - Right
    JB welding a crack - wrong
    inserting helicoils in stripped threads - right
    jb welding stripped threads - wrong
    etc.......
    Best advise I can give you is to do the job right the first time, it costs less in the long run as it will save you the "time, work, and money" wasted on stuff like JB weld. Then you have peace of mind the repair will last.
  6. cscmc1
    102
    Mar 15, 2006
    Indeed I am... sorry for the incorrect terminology. I've swapped headers on my Mustang so many times I just toss that term around w/o consideration. Edit made -- thanks for the clarification!
  7. cscmc1
    102
    Mar 15, 2006
    So it sounds like the crack, if not too bad, can just be welded, negating the need for a temp fix while I look for a replacement manifold... am I right?
    Thanks all!
  8. Agnem
    Agnem Using the Force! Staff Member Supporting Member
    54
    16,963
    42
    If welded properly, you need not find another manifold.
  9. Mr_Roboto
    1,721
    Dec 23, 2005
    I had no problems with the one I welded for the time I owned the car.
    The worst you can do is waste the cost of a package of special welding rod.
  10. cscmc1
    102
    Mar 15, 2006
    Thanks, guys. I'll try that route. I only have a wire feed welder, so I'll have to find someone to do this for me... but it's certainly worth a try! Maybe I'll get lucky and be able to do it w/o fighting to remove the manifold, as the crack is along the top and easy to see. D'ya think?
  11. Agnem
    54
    16,963
    42
    Might be able to get to it throught the wheel well if you remove the piece that snaps in.
  12. tonkadoctor
    3,776
    May 5, 2006
    none ya bidnes
    It will probably cost you as much if not more to get it welded by somebody who can weld cast iron properly than it will be to replace it with a used one and possibly a new one. Done right the weld is fine and you may never have to replace it, done wrong and that cast iron will crystalize and crack or shatter very quickly.
    Used manifolds for the 7.3 run anywhere from $10 - $100 each at a salvage yard and you can get a new one from Advance auto parts for $109 and Autozone can get one for $99.99
    If you want to check for a used one use www.car-parts.com It's a search through salvage yard inventories all over the states and you can locate parts in your area as well as get the prices here.
Share This Page
